Activity › Forums › Adobe After Effects › Trying to do Creating Planets & Auras Tutorial
  • Trying to do Creating Planets & Auras Tutorial
    Posted by Craig C smith on June 17, 2005 at 10:55 pm
    I am having a couple of problems trying to follow the directions.
    problem 1: on page 3 of 8,where did Aura Front Comp come from? I do not see that comp. I see Aura Map
    Problem 2: on page 4 of 8, Under the Transparency Map, paragraghs 2,3,4 or a little confusing.
    Any help would be deeply appreciated.Thanks in advance
    Serge Hamad replied 21 years, 3 months ago 2 Members · 2 Replies
  • Serge Hamad
    June 19, 2005 at 7:41 am
    Hi ccsmith7,
    I will get back to you on this one after checking the tutorial myself as I wrote it a while ago.
    Give me a day (Father’s day) and I will help you to get through it.
    Salut.
    Serge
  • Serge Hamad
    June 19, 2005 at 6:28 pm
    Please Ignore the Screenshot that says Aura_Front Comp.
    “Aura_Map” is what you should be using as a layer map.
    I will correct paragraph 3 to Aura_Map layer instead of Aura_Front layer.
    Let me know if you need some help.
    Salut.
    Serge
