Activity Forums Avid Media Composer Trying to customize the timeline
  • Trying to customize the timeline
    Posted by Olivier Prudhomme on September 19, 2014 at 2:46 pm
    Is there a way to add between the V and A tracks the same navigation bar we have on top of the timeline?
    I think I saw this one day.
    It would be very useful so I don’t have to move the mouse all the way up to move around in the timeline. (I use very large time line display)
    Same question re: the tracks column that are on the left. Can we get them on the right as well so I limit mouse traveling for these annoying track selection ?
    William Busby replied 11 years, 12 months ago 4 Members · 4 Replies
  • Michael Phillips
    September 19, 2014 at 3:16 pm
    You can drag the TC track between V and A tracks and save that as a view. There is no way to add track selector to the right side – perhaps map Tracks to keyboard and use those?
    Michael
  • Shane Ross
    September 19, 2014 at 3:27 pm
    OK…question 1. Yes, you can. IN the little FAST MENU (also called HAMBURGER MENU) on the very bottom left of the timeline…click on that. Looks like an ice cream sandwich. IN there, choose the option SHOW TRACKS. Make sure that TC1 and EC1 are checked. I keep EC 1 on the bottom to click on to get out of segment mode, and I put TC1 in between my video and audio tracks.
    Now to move it. Hold the OPT key, and then click on the track you want to move…TC1…and drag it up or down…where you want it to go. Done.
    As for Question 2…sorry, those don’t move. That’s where they will live, and there’s no way to get another set on the right
    Shane
    Little Frog Post
  • Olivier Prudhomme
    September 19, 2014 at 10:05 pm
    Thanks Shane. Works perfectly.
    (sitll looking for EC1 though)
  • William Busby
    September 20, 2014 at 8:43 pm
    Btw, unless you have the “smart tool” active there’s no need to move the mouse any particular spot to move around the timeline. The first thing I did was shut off the smart tool. I’m on 5.53, so if things have changed, I apologize 🙂
