Activity Forums Adobe Premiere Pro Trying to create Widescreen SD DVD
  • Trying to create Widescreen SD DVD
    Posted by Joe Bandy on July 29, 2009 at 4:30 pm
    I’m trying to create a Widescreen DVD in Encore CS3 with no letterboxing. I use the CS4 Media encoder to export video at 720×480 Progressive widescreen pixel aspect ratio, Quality high, CBR at 8
    I then created a SD DVD project in Encore and noticed that all the clips looked stretched to me. I tried playing them in Power DVD and they look normal or not stretched.
    I then tried to create a image and a disc in encore and recieved an error Internal software error at 00:00:00:00 %0, line Intro Part 1 of 2 – PGC info: name = Intro Part 1 of, ref = BPGC, time 00:00:00:00.
    I looked at my project settings and I don’t see anything that I would change to make the project SD widescreen. I thought you could do this in this program What am I doing wrong?
    Please Help, I have to be able to do this today!
    Mike Cohen replied 17 years, 1 month ago 4 Members · 5 Replies
  • Brian Louis
    July 29, 2009 at 5:24 pm
    720×480 wide screen will appear stretched on a 4:3 tv as its anamorphic video with a par 1.2 there should be a flag in the video that tells that DVD player that it wide screen and outputs correctly if it detects a wide screen. what are you trying to view on what?
  • Joe Bandy
    July 29, 2009 at 6:45 pm
    I also noticed that Encore is having trouble exporting 2 clips that I created in CS4. The I exported them the exact same way but the clips that encore is having problems with have a pixel aspect ratio of square 1.0. The other clips have a pixel aspect ratio of 1.2 (widescreen) When I remove the 2 clips with ratios of 1.0 I was able to successfully build a image.
    If I put them back on the timeline and conform them to 1.2 I cannot build a image.
    I’m guessing that somthing is wrong with my export from CS4. But I used the exact same settings.
    I tried authoring the same clips in both Encore CS3 and Encore CS4 and recieved the same error.
  • Jon Barrie
    July 29, 2009 at 10:19 pm
    Encore won’t support square pixel clips, re-export them out and make sure the PAR setting is correct for DVD (0.9 for 4:3, 1.2 for 16:9 NTSC)
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Joe Bandy
    July 30, 2009 at 2:15 am
    I checked some other successful DVD Encore Projects in CS3 that use video clips that have square 1.0 PARs according to Encore. I checked the actual properties of those m2v files in premiere CS3 and it said the PAR is 0.9 and the export settings from the adobe media encoder in those projects is also set for standard 0.9.
    Encore must round up to the PAR up to 1.0 upon import, this doesn’t seem correct.
    We used the settings:
    mpeg 2-dvd
    export video and audio,
    720×480
    Progressive
    standard 4:3 (0.9)
    audio 16bit 48khz
    The video comes out letterboxed in Encore which is fine but we were trying to make the video full screen so we tried using the settings:
    mpeg 2-dvd
    720×480
    Progressive
    widescreen 16:9 (1.2)
    audio 16bit 48khz
    Now the clips I exported from CS4 using these settings did not cause any problems in Encore CS4 and were 0.9 PAR but the video clip that I exported from CS3 ended up being 1.2 PAR and I don’t know why.
    I think this is the problem because I tried transcoding that clip from 1.2 to 1.0 PAR in encore and was able make an image and a disc.
    Do I need to open the CS3 project in CS4 to get the correct widescreen pixel aspect ratio?
    Does Encore only support 1.2 PAR for Bluray?
  • Mike Cohen
    July 30, 2009 at 8:40 pm
    In Encore, right click the m2v file and select “interpret footage” – this may be greyed out unless you have interpretable video. Normally NTSC widescreen mpeg2 exports from Premiere work fine.
    I see you are making your MPEG-2 files Progressive – are you starting with Progressive source such as 720p? I had always heard that you should not convert interlaced video to progressive when going to DVD as it could affect playback. Not sure this is still (or was ever) true.
    Mike Cohen
