Activity Forums Adobe Premiere Pro Trying to create the RSS Visualizer text effect
  • Trying to create the RSS Visualizer text effect
    Posted by Chris Wright on March 11, 2008 at 9:44 pm
    Hello. I’ve been asked to create a short, 2 minute video with text that flies in, similar to Apple’s RSS Visualizer Screen Saver. Is there an effect in Premiere Pro that would work best in this situation? Or maybe a plug in for Premiere that would make text look like an RSS News Feed?
    Perry Cheng replied 18 years, 6 months ago 5 Members · 4 Replies
  • Vince Becquiot
    March 12, 2008 at 5:58 am
    You could keyframe several title layers with the basic 3D effect, animating the position, y rotation, and tilt, and probably get what you are looking for, but I hope you have some time on your hands.
    This would be easily done in AE.
    Vince
  • Jon Barrie
    March 12, 2008 at 7:07 am
    AE is where I would do something like this, but there is a way, a nasty way to do it in PProCS3 if this video I’ve posted is what you are refering too. link here
    You need the Basic 3D effect on a text layer that is set to roll, then right click the text layer to open the Frame Options. “Reverse field dominance and none” will give you a nice look.
    I put a gradient in the background with a box in Titler that was filled with a gradient and stretched to fit the shading into the window the way I liked it.
    – Jon
    How many editors does it take to change a light bulb?
  • Joseph Springer
    March 12, 2008 at 4:11 pm
    like my cohorts I would like to encourage you to do this in AE, trial version available here:
    https://www.adobe.com/products/aftereffects/?ogn=EN_US-gntray_prod_after_effects_home
    And here is a tutorial that should help:
    https://cowcast.creativecow.net/podcast/using-the-echo-effect-with–206
    Regards,
    Joe Springer
    Certified Adobe After Effects Training and Premiere Training Instructor
  • Perry Cheng
    March 12, 2008 at 4:53 pm
    Or do in flash, export as AVI or TGA sequencee if possible, import into PPRo. (There is a converter that will convert swf2avi as well that can import swf and make it .tga sequences with transparency.)
    Perry
