Activity › Forums › Adobe After Effects › Trying to create cartoony underwater effect
  • Trying to create cartoony underwater effect
    Posted by Robert Kornstein on December 26, 2012 at 1:13 pm
    I’m trying to create an effect of looking up at a water’s surface from below, but cartoony-looking, somewhat like in this video at the 1:45 mark – https://www.youtube.com/watch?v=YW64g68byKE
    I currently have it set up as a Cell Pattern, with Turbulent Displace applied, tied to an alpha matte of Fractal Noise to simulate the refraction of light. However, this is a bit too realistic and “procedural” looking for what I want, and I was wondering if anybody here had any suggestions as to how I could do it differently. Thank you for the help!
    Robert Kornstein replied 13 years, 9 months ago 3 Members · 3 Replies
  • Stefan Hinze
    December 26, 2012 at 3:09 pm
    Try the Cartoon-Look FX (i don´t know the english name) it´s build in AE.
    And maybe you want to lower the fps.
    Or try lowering Levels.
    (take a step back, to see the bigger picture)
  • Joseph W. bourke
    December 26, 2012 at 5:42 pm
    You could pretty easily do this with the Noise plugin – to duplicate the example you’ve shown, you’d need to make a 3D layer, and align it to the camera so that it’s above, almost like a sky, which of course, the surface would be from underwater.
    Play with the noise settings, and maybe add a Threshold effect to cut down on the number of “reflections” moving around. You could add a Tritone effect to get your colors, or a Colorama effect could give you a wider range of colors. If you want your “hero” to look as if he’s underwater, you could add a distortion map which uses the water layer to distort him, the way water refracts. You might also use a Compound Blur, using the water layer, to blur the hero to match. Depends on the level of reality you want, given that it’s a cartoon.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Robert Kornstein
    December 27, 2012 at 5:30 pm
    Thanks to both of you for your advice! I altered what I had slightly with the Cartoon effect and played around a lot with the alpha matte, as well as adding some motion to the Cell Pattern to make it look as though the waves were drifting as they changed. I also made the layer 3D and shifted the perspective to be more slanted, which helped A LOT. Thanks again!
