Activity Forums Adobe After Effects Expressions Trying to create a path with an array of positions :/
  • Trying to create a path with an array of positions :/
    Posted by Nick Hill on June 9, 2023 at 12:55 pm
    I’m being obtuse here – this should work surely?
    The setup: I have Null 1 to Null 11 at indices 1-11. I want to use their positions to create a mask on some footage. Here’s the code I’m using on the mask path property:
    let p = [];
    for (i = 1; i <=11; i++) {
    p[i] = thisComp.layer(i).position;
    createPath(p, [], [], true)
    I get the error “argument 1 to createPath must be 2 numbers”. Using this code in the textSource property of a text layer and outputting p.join(‘\r’), I get a string of numbers separated by commas, so the loop is working at least. Array.isArray(p) outputs True. And if I use this as the last line on the path expression, it works:
    createPath([[100,100],[200,100],[200,200]], [], [], true)
    I’ve used this approach before in other (much more complex) code, so I can’t work it out.
    Brie Clayton replied 3 years, 3 months ago 3 Members · 3 Replies
  • Dan Ebberts
    June 9, 2023 at 2:40 pm
    This works for me:
    p = [];
    for (i = 1; i <= 11; i++){
    L = thisComp.layer(i);
    p.push(fromComp(L.toComp(L.anchorPoint)));
    createPath(p,[],[],true)
  • Nick Hill
    June 12, 2023 at 9:32 am
    Amazing – thanks Dan!
  • Brie Clayton
    June 13, 2023 at 2:44 pm
    Thank you, Dan, for this solve!
