Activity Forums Adobe After Effects Trying to convert a comp to a print size…. How?
  • Trying to convert a comp to a print size…. How?
    Posted by Chris Huggett on December 9, 2005 at 1:49 am
    Hey guys
    I have been asked to save a frame of animation that i have done for a specific piece of promotion on a Light board. They have asked if i can give them a high res tiff file of 300dpi with the dimensions of 1.51 tall by 1.01 wide.
    Can anybody point me in the right direction to convert this into a comp.
    Cheers
    Chris
    Thehardmenpath replied 20 years, 9 months ago 7 Members · 10 Replies
  • 10 Replies
  • Steve Roberts
    December 9, 2005 at 1:55 am
    DPI is dots per inch, which in a digital context, means pixels per inch.
    So ….
    1 inch at 300 dpi is 300 pixels.
    2 inches is 600 pixels.
    It sounds as if you’ve been asked to create something 1.51×300 pixels tall, by 1.01×300 pixels tall. So I’d wager it would be 453 pixels tall by 303 pixels wide.
    Steve
  • Chris Huggett
    December 9, 2005 at 2:01 am
    hehehe… Steve, my apologies… i thought you could read my mind… I missed off the metres of my dimensions..
    so it should be 1.01×1.51 metres
    thanks again
    chris
  • Andrew Yoole
    December 9, 2005 at 2:19 am
    So you need to create a new comp which is 11930 x 17835 (phew!).
    Drop the artwork comp into the new comp, collapse transformations and scale to fit the new dimensions. Vector based art and text should work fine, but any pixel-based artwork/footage will be very soft, depending on the original resolution.
    Then go Christmas shopping while it renders!
  • Chris Huggett
    December 9, 2005 at 2:34 am
    Thanks Andrew…
    It is a massive file and it looks like my dual xeon 3ghx can not handle that size. No matter what i try, it won’t render just a still.
    Do you have any ideas?
    All i have is a text layer with shine applies to it. Is there a similar shine plugin for Photoshop?
    Cheers
    Chris
  • John Dickinson
    December 9, 2005 at 3:08 am
    Hi Chris,
    I hate it when clients come to us and ask us to make print resolution versions of broadcast graphics
  • Steve Roberts
    December 9, 2005 at 3:23 am
    I thought it was a little too easy …
  • Steve Roberts
    December 9, 2005 at 3:27 am
    Yeah, that sort of thing is nasty. This is where specific details in estimates are important. When you have the say, of course.
    John’s right: GF is the classic app for that sort of thing, but you might want to check out Resizer.
    Steve
  • Jonathan Miller
    December 9, 2005 at 3:46 am
    I rmember a good article in DV magazine from October where John Jackman explained how to do just this using GF on a video still.
    https://www.dv.com/news/news_item.jhtml?LookupId=/xml/feature/2005/JackmanVidforPrint.1105
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
  • Michael Szalapski
    December 9, 2005 at 4:46 am
    Here’s a Photoshop plugin that’s sorta shine-y.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Thehardmenpath
    December 11, 2005 at 11:48 am
    Precomp that composition and in another that is, for example, 11930 x 2000. Put the precomped layer on top and render it if you can. Then change the position to -2000 and render again and again until you finish. Merge all files in photoshop. If you can’t you will have to reduce that 2000 to a size your computer can manage.
    Good luck!
