Activity Forums Adobe After Effects Trying to continuously rasterize – but layer will only collapse transformations…
  • Trying to continuously rasterize – but layer will only collapse transformations…
    Posted by Chase Langley on April 3, 2019 at 10:49 pm
    Hi all!
    Long time lurker – finally with a big enough thorn in my ass to post.
    I have a precomp with a bottom layer that has an alpha and a layer above it set to screen. I’d like to continuously rasterize in order to have the screen work properly in the parent comp – something I know that I’ve done in the past.
    However – when I press the continuously rasterize button – it only toggles the “collapse transforms” setting on.
    What’s the deal? Is this something new with recent AE iterations? I’m working in CC 2018…. :/
    Thanks to anyone who can give me some insight! <3
    -Chase
    Alexandre Marchese replied 2 years, 9 months ago 3 Members · 3 Replies
  • Walter Soyka
    April 4, 2019 at 3:25 am
    “Continuously rasterize” and “Collapse transformations” share the same switch. It’s “continuously rasterize” when you’re applying it to a vector layer or a solid, and it’s “collapse transformations” when you apply it to a comp layer.
    You want to enable collapse transformations for your precomp layer in the containing comp, and if you have any vector/solid layers in the precomp itself, you probably want to enable continuously rasterize for them.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Chase Langley
    April 4, 2019 at 7:13 pm
    Hi Walter,
    This makes total sense – thank you! I had forgotten that layers within a “collapse transformations” enabled precomp also need the “continuously rasterize” toggle marked.
    Thanks again!
    -Chase
  • Alexandre Marchese
    December 15, 2023 at 2:48 pm
    Hope you’re doing well. Ran into a DaVinci Resolve issue that’s been a real head-scratcher, and your expertise might be the key to unlocking it.
    In AE, we’ve got that “Collapse Transformations & Continuously Rasterize” switch that’s like a Swiss Army knife for keeping things sharp in nested comps. But in Resolve, I’m stumped. Here’s the deal:
    I’ve got a project with a main comp and a pre-comp. Tried a 25% scale on a layer inside the pre-comp and a 400% scale on the pre-comp layer in the main comp. Should’ve canceled each other out, right? Instead, it turned into a pixelated mess.
    So, here’s the million-dollar question: What’s the Resolve equivalent to AE’s “Collapse Transformations & Continuously Rasterize” switch? How the heck do we maintain clarity when dealing with different scales in nested compositions?
    Your insights would be a game-changer. If you’ve cracked this code or know someone who has, I’m all ears. Let’s cut through the confusion and get this sorted.
    Thanks a ton,
