Activity Forums Apple Final Cut Pro Legacy Trying to consolidate a sequence – why won’t FCP delete unused media?
  • Trying to consolidate a sequence – why won’t FCP delete unused media?
    Posted by Gareth Randall on May 19, 2011 at 6:28 pm
    I’m trying to archive a bunch of old projects by consolidating their sequences and deleting all the unused media to save on storage space. For some reason, though, FCP 7 isn’t actually letting me delete the unused media, even though I’ve got “Delete unused media from selected sequence” switched on in Media Manager.
    Typical example – I’m working in DV and I captured a total of 2.8 GB of rushes. The final edited sequence is 1’30” long. That’s about 326 MB of DV. I select the sequence in the Browser, right-click and choose Media Manager, and then no matter what options I select, the Original and Modified project sizes are 2.8 GB.
    With the “Delete unused media…” option checked, I’m expecting the Modified project size to read <400 MB because it will only copy the media actually used in the sequence, plus handles and music tracks etc. What’s the problem? Am I misinterpreting how consolidation works?
    Chris Mallett replied 15 years, 1 month ago 4 Members · 6 Replies
  • Gareth Randall
    May 19, 2011 at 6:53 pm
    Yep, everything has a reel number. But would it really make a difference to the consolidation process if it didn’t, given that I’m trying to copy the used media to a new project and delete all the unused stuff? I could understand lack of reel numbers being an issue if you’re planning to delete all the media with the intention of recapturing at a future date if necessary.
  • Shane Ross
    Does all the footage have a REEL number?
    Shane
  • Shane Ross
    May 19, 2011 at 6:59 pm
    Well, FCP’s media manager doesn’t do well with media when it lacks a REEL number. It is just one of the required things FCP needs. Name, timecode, reel number.
    Try trashing prefs and consolidate again?
    Shane
  • Joao Paulo
    May 25, 2011 at 8:51 pm
    Same here. Checked reel name, trashed preferences, restarted resetting RAM, created a new project, duplicated the original media and tried to consolidated through the new files: none of these worked.
    Any other ideas?
  • Joao Paulo
    May 25, 2011 at 11:17 pm
    Is the presence of .wav files somehow an issue?
  • Chris Mallett
    July 21, 2011 at 9:57 am
    Select the sequence, in the modify menu select ‘Make Sequence Clips Independent’ then try media manager. This worked for me. (FCP v7.3)
