Activity › Forums › Maxon Cinema 4D › Trying to close geometry and subdivide
  • Trying to close geometry and subdivide
    Posted by Cameron Butterfield on September 12, 2018 at 7:57 pm
    Hello!
    I’m trying to close the back of this windshield geometry. I think I successfully have by using the edge selection tool and stitch and sew. However, it leaves me with an unsightly weird looking plane and when I try to subdivide it, I can’t get a result to look like the front of the glass. Any ideas on how to give this object smooth polygons (like the front) and close the back properly? I tried using Subdivison surface as well.
    Thank you!
    FRONT
    OPEN BACK
    CLOSED BACK
    SUBDIVIDED
    Cameron Butterfield replied 8 years ago 2 Members · 2 Replies
  • Steve Bentley
    September 12, 2018 at 11:18 pm
    What about just nesting the object (less the added “back” and sides) inside a cloth object ) then you can set the thickness. Is that what you are after or do you truly want a flat plane to span the back?
    In this instance you can think of the cloth as a normal-directed, full object extrude.
  • Cameron Butterfield
    September 13, 2018 at 12:50 am
    Thats perfect! Using Cloth Surface and extruding just a little bit, fixed it right up. Thank you!
