Activity Forums Apple Final Cut Pro Legacy Trying to Capture SD in FCP without deck control
  • Trying to Capture SD in FCP without deck control
    Posted by Dyan Bailey on July 23, 2008 at 3:21 pm
    Hi!
    I’m using a Digi-beta source and have everything set to 10 bit uncompressed in my Audio/Video settings. AJA KONA LH and all I am seeing is a grey screen. Everything seems to be set up right, but nothing is showing up. HELP!!!!
    Matt Callac replied 18 years, 2 months ago 4 Members · 6 Replies
  • Liam Stephens
    July 23, 2008 at 4:05 pm
    Call AJA 1-530-274-2048 – The info u have provided is a little vague they will talk u off the ledge. Also your subject is completely different to your problem…
    Mac 10.5.4
    FCP 6.04
    2 x 2.8ghz Quad Core Intel Xeon
    16gb RAM
    7 TB Maxx RAID
    AJA Kona3
  • Rafael Amador
    July 23, 2008 at 4:46 pm
    Have you set: Non-controllable device?
    rafael
    http://www.nagavideo.com
  • Matt Callac
    July 23, 2008 at 4:51 pm
    I usually call AJA as a last resort after I troubleshoot and then check the cow. Also you have very little info to go off of in your post. I’d suggest you check your aja control panel to make sure you are getting signal. You could have it set to SDI rather than analog.
    -mattyc
  • Dyan Bailey
    July 23, 2008 at 4:53 pm
    yes. We got it to work going analog in, but really need to figure out getting SDI in.
  • Dyan Bailey
  • Matt Callac
    July 23, 2008 at 4:59 pm
    Sorry, I missed the Digi part of your OG post. SO your Control Panel is set to SDI?
