Activity Forums Maxon Cinema 4D Trying to apply an image in the new C4D
  • Trying to apply an image in the new C4D
    Posted by Chuck Obernesser on September 18, 2013 at 12:41 am
    Hello to all,
    I am trying to create a hockey puck with a team logo applied to the top. I just downloaded r15 and when applying the image to the color/texture. It is tiling when I click it off and I can’t find the scale anymore. Were these moved? If so how does one apply an image with an alpha channel to an object?
    Chuck
    Dan Conrad replied 12 years, 11 months ago 2 Members · 1 Reply
  • Dan Conrad
    September 18, 2013 at 9:28 pm
    Make sure you are using “Flat” projection mode then rotate the projection into place with the Texture tool. As for the Alpha, load the same image with an alpha in the Alpha tab of the material.
    http://www.mographcandy.com
    Twitter: @mographcandy
