Activity › Forums › Adobe After Effects › Trying to animate only y possition with an expression
  • Trying to animate only y possition with an expression
    Posted by Nick Esposito on June 10, 2006 at 5:04 pm
    I’m trying to animate the y motion of a layer with an expression that references audio keyframes.
    My problem is that I can’t isolate only the y axis with the whip. Any ideas?
    Cheers!
    Nick Espo
    Matt Silverman replied 20 years, 3 months ago 5 Members · 11 Replies
  • 11 Replies
  • Mylenium
    June 10, 2006 at 5:42 pm
    Assuming you used the “Audio to Keyframes” keyframe assistant, this will work:
    [position[0],thisComp.layer(“Audio Amplitude”).effect(“Left Channel”)(“Slider”)]
    Mylenium
    [Pour Myl
  • Dan Ebberts
    June 10, 2006 at 5:59 pm
    If you just want to offset your y position with the audio amplitude, you probably want something like this:
    multiplier = -5;
    audio = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    value + [0,audio*multiplier]
    Adjust multiplier to set the direction (minus is up) and amplitude of movement.
    Dan
  • Nick Esposito
    June 10, 2006 at 7:24 pm
    Thanks for you answers, I did use convert audio to keyframes.
    My problem is I can’t animate only the y position.
    When I add the expression it effects both the x & y
    How would I make the expression target only the y axis of movement?
    Cheers!
    Nick Espo
  • Dan Ebberts
    June 10, 2006 at 7:53 pm
    Which expression are you talking about? Either of the ones suggested here should only affect y.
    Dan
  • Nick Esposito
    June 10, 2006 at 8:03 pm
    Thanks guys for your time!
    I used this one:
    For my own edification. How would I change this expression and make it effect the y axis?
    Cheers!
    Nick Espo
  • Dan Ebberts
    June 10, 2006 at 8:16 pm
    That expression should move your layer to the top of the comp (without changing the x position) and bounce it downward in response to the audio (i.e. on the y axis only). Is that not what it does for you?
    Dan
  • Nick Esposito
    June 10, 2006 at 8:28 pm
    It works great. Thanks for saving the day. But why does it work?
    Like in:
    Is it [position[0] that isolates the y axis? How would I isolate the x axis?
    Thanks!!!!
    Cheers!
    Nick Espo
  • Dan Ebberts
    June 10, 2006 at 8:35 pm
    position[0] is the pre-expression x value (static value + effect of any keyframes). So this expression:
    says – use the pre-expression x value for x and the audio amplitude for y. To keep the original y value and affect x only, you’d do it like this:
    [thisComp.layer(“Audio Amplitude”).effect(“Left Channel”)(“Slider”),position[1]]
    Dan
  • Nick Esposito
    June 10, 2006 at 8:41 pm
    OK. I’ll try to understand that.
    Thanks for the help!
    It works great.
    Cheers!
    Nick Espo
  • Steve Roberts
    June 10, 2006 at 9:05 pm
    The old long-form way of writing “position” may be instructive:
    {position[0],position[1],position[2]]
    … means “x position, y position, z position” for a 3D-enabled solid. If you write that (or just the two-dimensional version) then highlight “position[1]” and pickwhip to it, you’re in business.
    There are other ways. Search the COW for “Ebberts” as author, and copy the posts to a word processor. Dan’s posts are worth saving, and he never wastes a post.
