Activity Forums Adobe After Effects Expressions Trying to add dashes to lines via Scripting (Not working)
  • Trying to add dashes to lines via Scripting (Not working)
    Posted by Vincenzo Imbimbo on April 8, 2023 at 5:11 pm
    Hello guys, i don’t know why my code is not working, anyone can help me?
    I created a button that add dashes to selected shape layers, and it seems to be fine but is not working.
    buttonDashes.onClick = function (){ app.beginUndoGroup("Set Dashes");
    var project = app.project;
    var comp = project.activeItem;
    var myLayers = comp.selectedLayers;
    for (var i = 0; i < myLayers.length; i++){
    tryLineCap(myLayers[i].property("ADBE Root Vectors Group"))
    function tryLineCap(prop) {
    for (var j = 1; j <= prop.numProperties; j++){
    var subProp = prop.property(j);
    if (subProp.numProperties) {
    tryLineCap(subProp)
    } else {
    if (subProp.matchName == "ADBE Vector Graphic - Stroke") {
    subProp.property("ADBE Vector Stroke Dashes").addProperty("ADBE Vector Stroke Dash 1").setValue(20);
    app.endUndoGroup();
    Vincenzo Imbimbo replied 3 years, 4 months ago 3 Members · 3 Replies
  • Tomas Bumbulevičius
    April 8, 2023 at 5:47 pm
    Vincento – describing what does not work could help to get into the issue without even running the code
  • Dan Ebberts
    April 8, 2023 at 7:19 pm
    I’m not sure about your recursive property navigating function, but going right at it like this works:
    myLayers[i].property("ADBE Root Vectors Group").property("ADBE Vector Group").property("ADBE Vectors Group").property("ADBE Vector Graphic - Stroke").property("ADBE Vector Stroke Dashes").addProperty("ADBE Vector Stroke Dash 1").setValue(20);
  • Vincenzo Imbimbo
    May 5, 2023 at 4:49 pm
    Hello Dan!! Thank you for your reply, i tried what you tell me and it works perfectly, but the problem is that i want it to be applied to any selected shape layer (or layers) no matter how many shapes and groups are inside this layer/layers, that’s why i was using that recursive property navigating function but i don’t know how to merge that function with the navigation that you gave me, can you help me? Thanks!
