Activity › Forums › Apple Final Cut Pro Legacy › Trumpet sound in background… help!
Posted by Beamer Films on August 13, 2009 at 10:23 pmHowdy, all. I was on a shoot yesterday and a nearby trumpet player decided that it was his time to play while I’m doing an interview… There was nothing I could do to change locations or get “better” audio, so I moved forward with the shoot. It was far enough away to be distant, but close enough to annoy…
I’ve been utilizing the 3 band equalizer to try and pinpoint that pesky trumpet, but having no luck, to be honest.
I’m looking for advice… can anyone help guide me? I’m not real experienced in sound…
cris
Chris Poisson replied 17 years, 1 month ago 6 Members · 6 Replies -
Ron Craig
August 14, 2009 at 2:09 amI hate to make you feel worse but I don’t see any way that you’re going to have any luck removing that trumpet. Even if you were experienced in audio you wouldn’t have any luck.
Just imagine that the trumpet sound is actually the sound of another person standing nearby, talking. You’d never be able to remove that second voice, right? The trumpet is no different.
If you have a narration/voice-over on this piece and you absolutely must use the interview, you might consider having the narrator very briefly call attention to the fact that there is a trumpet playing nearby during the interview. That “inoculates” you a little bit from your error.
And frankly, you have to accept this as an error in judgment and learn from it (as I have done so many times in my career). You say that you had no choice other than to proceed with the interview. Frankly, that is never true. Move the interview someplace far away. Delay the interview. Go talk to the trumpeter and ask for 15 minutes of silence. Do anything…but don’t record trumpet playing during an interview. If you just accept the trumpet playing during an interview then what you have is a trumpet playing during your interview — forever.
Michael Gissing
August 14, 2009 at 3:07 amAnd to make things worse, you have to clear copyright if the tune is recognisable.
Vince Sanchez
August 14, 2009 at 5:40 amI do audio post on a reality type show and you never know what’s going to show up in the background. I’ve had several instances where there is music in the background, so what I do is add some music from our library and i can usually mask the offending music. The ear is easy to fool. If you start the music a little higher in volume and then slowly ease it down, the listener will only really hear that in the background. It the way our brain deals with the cacophony that’s going on around us.
If your going to edit this interview you’re definitely going to have to do something as the background music will jump all over the place.Thanks,
Vince Sanchez
Intel Quad Mac 2.66
AJA LHe
HD link
OSX 10.4.11
FCP Studio 2 -
Beamer Films
August 14, 2009 at 12:46 pmThanks all. Glad for the thoughts and info. Naively, I was hoping there was a way to isolate the higher pitch tones (again, I’m no audio guru). Vince, I’ll give your thoughts a whirl, though. I was trying that initially, and it worked until I hit a certain point.
I’ll figure something out and make it work! Again, thanks for the help!
cris
John Fishback
August 14, 2009 at 1:58 pmiZotopeRX https://www.izotope.com/products/audio/RX/
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Chris Poisson
August 14, 2009 at 3:00 pmThere’s a new feature in Soundtrack Pro which deals with removing certain sounds, in the tutorial they are removing or minimizing a bird, go to the Apple site and look at the new features tutorials.
Have a wonderful day.
