Activity Forums Maxon Cinema 4D True RGB colors – No light , no shadow
  • True RGB colors – No light , no shadow
    Posted by Markus Hofko on November 17, 2009 at 1:39 am
    Hi there!
    I’ve got an apparently easy problem to solve:
    Floating/turning cubes with specific rgb-color-values on each side.
    These colors need to stay the same all the time, which means no shadow/light influence.
    I can kinda simulated this with a surrounding white sphere and GI but it’s not completely color-true.
    Is there a way to achieve this?
    Markus
    Markus Hofko replied 16 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    November 17, 2009 at 3:20 am
    put the colors in the Luminance channel (make the color in the Color channel be the same or black or turn the Color channel off or you will get a different color)
  • Markus Hofko
    November 17, 2009 at 7:33 am
    Fantastic, thanks! Color needs to be black though. Same color makes it too bright. Cheers!
