Activity Forums Adobe Photoshop True 3D text?
  • True 3D text?
    Posted by Steve Morris on January 2, 2006 at 11:09 pm
    I can not seem to find the command to make a 3d text layer with depth (extrude). I can manipulate the layer in 3d, but the layer has not depth. I have found something in the EFFECTS > 3D Channel that has variaables for the “Z depth”. Changing the Z dimension does not seem to affect the depth of the text.
    I am using AE 6.5 and am well versed in other 3d programs such as 3D Max.
    Steve Morris replied 20 years, 8 months ago 2 Members · 3 Replies
  • Jim Kanter
    January 3, 2006 at 6:09 pm
    There is no native capability to give objects true 3D volume. For that you need something like Zaxwerks Invigorator or a true 3D app.
    AE gives you 3D compositing space. Every layer is still essentially a flat screen on whose surface content appears.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Jim Kanter
    January 3, 2006 at 6:11 pm
    Whoops, wrong forum (thought this was AE).
    You can simulate 3D by applying layer styles like Bevel.
    Jim Kanter,
  • Steve Morris
    January 6, 2006 at 3:54 pm
    Whoo. I did post this in the wrong forum. I have been trying to find this post for the last week. I just found it today. I did intend it to be be in AE.
    Thanks for your reply. I will need to use 3d max for part of my intro.
