Activity › Forums › Adobe After Effects › True 3D sphere in CS6?
Posted by Steve Brame on June 25, 2012 at 4:30 pmTrying to work with the new 3D capabilities in CS6. I’m used to ProAnimator and others. I’m seeing possibly that AE cannot create a true 3D sphere natively, but can only perform a linear extrude of a 2D object. Note that I’m not talking about CCSphere type 3D sphere, but a true 3D sphere that a camera can fly around.
“98% of all computer issues can be solved by simply pressing ‘F1’.”
Steve Brame
creative illusions ProductionsDavey Jones replied 13 years, 2 months ago 6 Members · 11 Replies -
Nevin Styre
June 25, 2012 at 9:11 pmYeah I’m pretty sure CS6’s native 3d is limited to extruded flat planes with bevel options.
Todd Kopriva
June 26, 2012 at 3:00 amYou can make a sphere by extruding a period or circle with a curved bevel. Try it.
product manager, professional video software
After Effects team blog
Premiere Pro team blog
Steve Brame
July 2, 2012 at 6:56 pmWith a max bevel setting of “10” it doesn’t work very well. All we get is a cylinder with rounded edges.
Steve Brame
creative illusions Productions -
Todd Kopriva
July 9, 2012 at 10:19 pmThe maximum bevel depth setting is not 10. That’s just the default maximum for the slider. You can type in a larger number.
Also, as with almost all slider controls, you can change the maximum by right-clicking/Control-clicking the value and choosing Edit Value.
Dustin Parsons
July 30, 2012 at 9:03 pm[Todd Kopriva] “The maximum bevel depth setting is not 10. That’s just the default maximum for the slider. You can type in a larger number. “
The bevel depth appears to max out at 100 though and for me that doesn’t round the corners enough for a sphere.
This is what I get with the Bevel depth set to 100:
Any thoughts?
Maarten Francq
July 31, 2012 at 8:23 am -
Dustin Parsons
August 7, 2012 at 1:36 amInteresting. I got it to work using your method but I realized that I had to keep the text size small, once it got past 100px that’s when the sphere started loosing it’s shape and becoming more pill like (see this image).
Maarten Francq
October 29, 2012 at 3:58 pmHi,
I made an entire animation using this idea. Some frames out of it can be seen on https://www.lowstreetmedia.be/raytrace-3d-inside-after-effects-based-on-fonts/
Kind regards,
Maarten
Davey Jones
July 30, 2013 at 1:46 pmTrying to apply your technique, but I am not getting the same geometry options under the text layer that you show in your graphic. I made the period a 3d layer, but didn’t help. Any ideas. I am using AE CS6. Thanks.
Maarten Francq
July 30, 2013 at 3:32 pmDavey,
Make sure the current renderer is set to 3D Raytrace.
Steps from the helpfile:
1.Create a new composition.
2.Open the Composition Settings dialog box for the composition.
3.Click the Advanced tab, then set the Rendering Plug-in (now called Renderer) to Ray-traced 3D.To turn an existing composition into a Ray-traced 3D composition, omit the first step.
Your composition is now a Ray-traced 3D composition that allows for extruded text and shapes.
Hope this solves your issue.
kind regards,
Maarten
