Activity › Forums › Apple Final Cut Pro Legacy › True 24p PAL – IS IT POSSIBLE W/FCP 5.0???
Multitoncolor replied 20 years, 2 months ago 7 Members · 13 Replies
Felix Bueno
July 27, 2006 at 7:35 pmHave you tried using this option in the menu: View/Video Playback/Digital Cinema Desktop Preview – Full Screen. With this option you’ll see your footage in true 24fps, without jumping and shaking.
You need dual screen to get this option. I use this setup to see HD and SD footage in my LCD monitor, and it works great. For example, you can use a 23″ Apple Monitor to work and a conventional 19″ LCD monitor to see the footage. (2 23″ Apple Monitors will be great) I don’t know if it helps but it’s the only solution I can find.
Good Luck
Felix Bueno
Power PC G5 Dual 2.0 Ghz
4 GB ram
GeForce FX 5200 64 Mb AGP
FCP 5.1, MacOsX 10.4.7
BlackMagic Decklink Extreme
2 ACER LCD 19″ monitors AL1916
300 GB SCSI2 StoreData Raid
500 GB G-RAID
DigiBeta Sony A500P
DVcam Sony DSR 1500P -
Sam Goetz
July 27, 2006 at 8:16 pmDigital Desktop Preview is definitely a good monitoring option, but clients tend not to trust it, and we need the ability to layoff to tape in a moments notice. Unfortunately you cannot go to tape with Digital Desktop Preview. You need 50i PAL.
Thanks though,
Sam -
Multitoncolor
August 3, 2006 at 3:31 amI don’t get the whole speed up thing.
there are only so many pegs and so many holes.
You have 24 discrete frames. and you want to convert them into 50 discrete fields.
Something has to give. there has to be some temporal sampling… it can’t just be sped up.
24fps sped up 4.1% would “make a hole” wouldn’t it? You speed them up to make the 25th frame but where does that come from?
M
