Activity › Forums › DVD Authoring › Troubles with MPEG streamclip
  • Troubles with MPEG streamclip
    Posted by Katie Maguire on September 27, 2009 at 10:52 pm
    Hello,
    I’m having trouble opening a dvd and exporting it to quicktime so that I can import it into final cut. On DVD player, the DVD has a running time of around 56 minutes (divided into about 10 chapters). When I open the dvd in Mpeg Streamclip, I am about to access the following files: VTS_01_1.VOB, VTS_01_2.VOB, VTS_01_3.VOB, VTS_01_4.VOB, VTS_01_5.VOB. However, on Streamclip, these files only play for 5 seconds. I opened the DVD again in Mac the Ripper to see if I could re-rip the files but I had the exact same problem.
    Is this fixable?
    Katie
    Chris Linke replied 17 years ago 2 Members · 1 Reply
  • Chris Linke
    September 29, 2009 at 2:29 pm
    Give this a try:
    Instead of opening as a DVD, go to “File > Open Files…”, select VTS_01_1.VOB, and when asked if you’d like to open all the files together, click “Open All Files”. If asked to fix timecode breaks, do so.
    Chris Linke
    PRC Digital Media
    http://www.prcdigital.com
