Activity Forums Compression Techniques troubles compressing 4 hour video for single layer DVD
  • troubles compressing 4 hour video for single layer DVD
    Posted by Sean Schiavolin on September 19, 2006 at 5:23 pm
    I am authoring a DVD that needs to contain 4 hrs of DV footage shot last week.
    After finding out that Compressor doesn’t have a mpeg2 setting that will compress it small enough to fit on a single layer disk. I tried with Quicktime and on it’s lowest setting it has it coming in at 4.5. So I tried it twice and quicktime has frozen up afer 7min of compression.
    Can anyone help me figure out my options. I need to get this DVD in the mail today.
    thanks!
    Sean Schiavolin replied 20 years ago 2 Members · 2 Replies
  • Charles Simonson
    September 19, 2006 at 6:22 pm
    I would suggest buying a software encoder that will allow you to encode to 1/2 D1 resolution MPEG-2 (352×480). This will allow you to encode to a much lower bit rate while still retaining good quality and DVD SP will be compatible with it. Such softwares that I recommend on the mac are BitVice, MainConcept, Episode, and MEGAPeg Pro. Alternatively, you can set your DVD up for a DL disc, which should afford you plenty of room to encode 4 hours to one DVD at full resolution.
  • Sean Schiavolin
    September 19, 2006 at 6:57 pm
    Charles,
    Thank you for recommending those encoding softwares.
    Very helpful.
