Activity Forums VEGAS Pro Trouble with Track Motion
  • Trouble with Track Motion
    Posted by Jeff Davis on February 3, 2010 at 9:51 pm
    I’m using Vegas Pro 9.0. When I use Track Motion to zoom in on a clip, the rendered video is zoomed in more than the preview. I’ve had no luck second-guessing the behavior by zooming to a level I think will work, regardless of the preview. Any suggestions on how to use Track Motion so the render corresponds to the preview? Thanks.
    Jeff Davis replied 16 years, 7 months ago 3 Members · 3 Replies
  • Mark Greenwood
    February 3, 2010 at 11:35 pm
    Are you rendering with a different setting to the prject. For example if your project is set to 720×576 NSTC and you are rendering to say 600×400 then the zoom and picture will be out – set the project in File / Properties to the same format you render to – that should then do the trick….
  • Danny Hays
    February 4, 2010 at 2:08 am
    You can also try “event pan and crop” for this.
  • Jeff Davis
    February 4, 2010 at 3:52 am
    That was it. Thanks.
