Activity Forums Blackmagic Design trouble with sd
  • trouble with sd
    Posted by William Eubank on June 22, 2005 at 10:31 pm
    hi i edited a project in 8 bit uncompressed hd using the decklink hd pro card. after i was done i output the project back to tape on a hdcam deck. i then wanted to use the decks down conversion sdi out to put a ntsc version back onto my computer. when i switched my fcp settings to 8 bit ntsc uncompressed, and tried to capture, fcp kept telling me it was missing the 8 bit ntsc 4.2.2 codec. i have intsalled all the new 4.8 drivers and codecs and the previews work fine and everything. what am i doing wrong. any help would be greatly apprecaited. thanks, will
    William Eubank replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
