Activity Forums Apple Final Cut Pro Legacy Trouble with RAM install
  • Trouble with RAM install
    Posted by Scott Davis on September 12, 2005 at 4:23 pm
    Ordered RAM from Crucial. All is going well except I can’t get my G5 to recognize the ships in slots 4 and 5. Have tried reseating a couple of times. Any other thoughts?
    OS 10.4.2
    G5 DP2Ghz (8 DIMM machine)
    Mitchji replied 20 years, 11 months ago 2 Members · 3 Replies
  • Mitchji
    September 12, 2005 at 5:09 pm
    Are you installing the RAM in the proper slots (paired)?
    If so its either a problem with the RAM or the MB.
    Best Wishes,
    Mitch
  • Scott Davis
    September 12, 2005 at 9:50 pm
    Yes matched pairs.
  • Mitchji
    September 12, 2005 at 10:18 pm
    [Scott Davis] “Yes matched pairs.”
    Hi Scott,
    The RAM is supposed to be installed in one DIMM of the pair in each bank starting from the center of the banks and working toward the outside. If you have done that and they are seated properly it has to be a problem with the chips or the mother board.
    Best Wishes,
    Mitch
