trouble with precomps
Posted by James Corsolini on December 6, 2011 at 8:42 pmI am animating a butterfly’s wings. No problem there. But I can’t figure out how to then bring that 2sec comp into another longer project so I can fly it around. This was straightforward in AE, but not so much in Boris. BTW, I’m using AvidFX with my Media Composer. I guess that’s the same as Boris Red 4? Thanks!
Marcus Warren replied 14 years, 9 months ago 4 Members · 15 Replies -
Peter Mcauley
December 6, 2011 at 9:37 pmHi,
You can use the Composition>Insert Composition command to do that.
I hope that helps.
Peter.
James Corsolini
December 7, 2011 at 2:57 pmPeter,
I tried that. First off, I’m not sure how to save a composition. I can save a project. And when I do Composition>Insert Composition, I find the 2 sec project I saved and it inserts it into my longer project and stretches it out to the length of my longer project – ruining the timing of the animation, and providing me no way to use this as a looping precomp.
I know I must not be understanding something. Is there a tutorial that would help explain this? -
Peter Mcauley
December 7, 2011 at 3:36 pmHi James,
Here’s the workflow:
To save a project / composition:
• generate the project that you want to save
• select file>save project as
• provide a destination and a name
• click the save buttonTo insert a project / composition into another project / composition:
• start by creating or opening a project to which you want to add another composition
• go to the keyframe palette window
• enable the “keep keyframe time” option to preserve the original time of the composition
• disable the “keep keyframe time” option to stretch the inserted comp length to match the current comp
• select composition>insert composition
• select the comp that you wish to insert and click the open buttonI hope this helps.
Peter.
James Corsolini
December 7, 2011 at 3:51 pmPeter,
that helps a lot! Now, once I’ve inserted this 2s animation of butterfly flapping wings, into my longer animation. How do I get it to “loop” for the duration of the longer composition? -
Peter Mcauley
December 7, 2011 at 9:24 pmYou can place the inserted composition tracks into a container, then copy and paste the container and shift the pasted versions in time along the timeline.
Or you could render out a movie file of the comp that you want to loop and then import this as a media item into the timeline. You can then click on the “face” sub-track of the imported movie and set the clip to loop by clicking on the “Loop Movie” checkbox in the control panel.
Cheers,
Peter.
James Corsolini
December 7, 2011 at 10:55 pmPeter,
Thanks for you reply. I have inserted the comp (inside a container) into the longer project. It looks like each iteration of the wing animation will have to be on its own track. Can’t just put them on the same track back-to-back right? That could mean there would be LOTS of tracks with a longer project.
As far as rendering it out, then I loose the 3D aspect of it right? I need to fly it around and have it turn, etc.
-james -
Steve Pankow
December 8, 2011 at 12:55 amTurning on Loop should make the shorter clip match the duration of your comp. You could then just send an end keyframe wherever you want it to end.
James Corsolini
December 8, 2011 at 2:29 amSteve,
Thanks for your reply. I don’t see a way to “turn on loop”. There is a filter call BCC Looper, not sure how that functions. AvidFX help is vague when it comes to explaining stuff. I thought I knew this program pretty well, but I feel pretty dumb right now.
I brought my laptop home and am using standalone mode.
Frustrating! -
Steve Pankow
December 8, 2011 at 5:17 pmLook at your .mov track in your comp. Twirl down to the Face track. Your Control Window menu should be showing a tab called Movie Media. On this tab is the Loop area, with a checkbox for Loop Movie and a dropdown for how you want your movie to loop.
James Corsolini
December 8, 2011 at 7:35 pmI do see the loop option like you say if I render the animation and then bring it in. The problem with that is that it is then no longer in the 3D world. I wanted to turn this and have 3D control of it while it flew.
I have settled for rendering a movie and then looping and flying it that way. I will assume then, that Boris just cannot do this.
Thanks for your responses and help, I have learned a lot with this!
-james
