Activity Forums Adobe Premiere Pro Trouble with HDV in Premiere Pro CS3
  • Trouble with HDV in Premiere Pro CS3
    Posted by Clay Miller on August 30, 2011 at 4:34 pm
    Cannot figure this out.
    I use CS3
    When I export HDV, the finished video is terribly jerky. I guess it is my computer system causing the problem, but I don’t know what will fix it. Do I need more RAM, faster speed, what? Or am I exporting wrong?
    Here are the details:
    Shooting HDV, 1440x1080i
    Intel dual core 6600 @2.40 GH
    3 GB RAM
    GEForce 9500 GTE video card
    Is that sufficient?
    What setting in CS3 should I choose for exporting?
    Ann Bens replied 15 years ago 3 Members · 4 Replies
  • Jeff Pulera
    August 30, 2011 at 9:06 pm
    Hi Clay,
    When you say exporting, does that mean Print to HDV tape, or export to a web format or other?
    Anytime you export to a web format, you should DEINTERLACE the video. In the Export settings, you may have a “deinterlace” checkbox, otherwise set “Fields” to “Progressive”.
    Jeff Pulera
    Safe Harbor Computers
  • Clay Miller
    August 30, 2011 at 10:27 pm
    I need to export to a wed format. I do deinterlace. The problem is very jerky stuttering playback.
    I assume I need to upgrade something with my system, but need to know what and how much.
  • Clay Miller
    August 30, 2011 at 11:12 pm
    Meant to say “web” format
  • Ann Bens
    August 31, 2011 at 7:21 pm
    Try wmvHD
    Adobe Certified Expert Premiere Pro
