Activity › Forums › Apple Final Cut Pro Legacy › Trouble with HD video and widescreen
  • Trouble with HD video and widescreen
    Posted by William Wasson on September 10, 2011 at 11:54 am
    I’m working with HD video 1440×1080. In the viewer it fills the screen but when i place it on the timeline it becomes widescreen with black bars. I’ve tried adjusting the sequence settings with bad results. I’ve worked with this type of video before with no problems, what am i doing wrong?
    William Wasson replied 15 years ago 2 Members · 2 Replies
  • John Pale
    September 10, 2011 at 3:05 pm
    That is most likely an HDV clip. Did you try an Easy Setup for HDV ?
    Don’t set everything manually. Use an Easy Setup.
  • William Wasson
    September 10, 2011 at 11:06 pm
    thanks i got it to work!
