Trouble with creating a background environmental mapping scene using element/skybox/horizon etc.
Hello
Well i am trying to create a scene using a 2d image(1920*1080) and look like a 360 video. Now i am facing issues as follows.
1 Trapcode horizon – When i apply horizon to the image the pixels are breaking apart. There is damage restored when i adjust the H and L values,Straighten,Scatter sampling etc. But not getting a decent output.
2 Skybox – It has better output than horizon but there are a lot of variables involved, i am trying to learn but it will take time i guess.
3 Element 3d – I think this is easiest way atm to create the scene inside of setup using environment . Somehow the output quality is not great.
4 Environment effect is greyed out in my ae. It wont be of any use if it was there.
There is another method i used to make copy of the background,rotating it to 90 degrees ,joining end to end and setting up a scene .The major problem was at the 90 degree bend of the image ,tried my luck using blending option but no use. although it did look like inception ? but then that is what i didn’t want. Also does corner pin effect be applied on image using horizon/skybox/element and what is the image quality recommended to use with all these plugins.
I am using after effects CC 2015.
