Activity Forums Apple Final Cut Pro Legacy Trouble with Boris AAF Transfer
  • Trouble with Boris AAF Transfer
    Posted by Scott Stolzar on October 25, 2010 at 6:09 pm
    Hi
    I’m not sure whether to post in the Avid section or here. I’m using the Boris AAF tool to transfer some HDV sequences from FCP 7.0.3 to Avid MC 4.0.5.10 which is hooked up to both Isis and Interplay. When I import the AAF file, I saw the sequence and the Associated master clips and subclips. Then I did a Batch Import and directed it to the HDV quicktimes captured in FCP and imported them. When that finished, I could play the master clips, but nothing was showing up in the sequence, and I kept getting an error that said: “Exception: PMM_INSUFFICIENT_MEDIA.” I’m not seeing a lot of posts about this topic. Thank you in advance for your help!
    Scott
    Scott Stolzar replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
