Activity Forums Apple Final Cut Pro Legacy Trouble with AVC codec
  • Trouble with AVC codec
    Posted by Sarah Reynolds on March 14, 2012 at 6:30 pm
    Hi Everyone.
    I have a 30min DVD, not copyright protected, that I need to grab a section from and edit down to about :30secs. I thought the best way to do this would be to use HandBrake to make a file, then import the file into FCP to make my edits. HandBrake made a file for me just fine, but it will only make an AVC file. I am on FCP 6.0.6, and I do not think AVC is supported. I get an error when I try to import.
    My question is, how do I get this file into FCP so I can make my edits?
    I have tried…
    -Converting it using QuickTime 7. It fails every time.
    -Tried MPEG StreamClip…fails every time.
    -Tried ripping the DVD using VLC player…can’t get it to work right. It will only do like :10secs of the clip
    I’m stumped! Please help if you can! Thank You!!!!
    Rafael Amador replied 14 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Juan Salvo
    March 14, 2012 at 6:38 pm
    Try copying the VideoTS folder to your hard drive, then use mpegstream clip to convert from the VideoTS folder.
    Alternatively, you could use MpegStreamclip to convert the AVC you made with handbrake.
  • Sarah Reynolds
    March 14, 2012 at 7:32 pm
    Thanks for the suggestions Juan.
    I tried to copy the Video TS folder and the computer will not let me copy and paste.
    Also, I had tried using MpegStreamClip to convert the AVC file that HandBrake made, and it just fails.
    Any other suggestions, please let me know! Thanks!
  • Dennis Leppell
    March 14, 2012 at 9:12 pm
    Problem you’re having with MpgSteamclip is strangely enough, broken timecode. Repair the time code (there’s a menu option for this), and you should be able to rip it just fine.
  • Juan Salvo
    March 14, 2012 at 11:27 pm
    You’ve got a bad disc. You need to find another copy. Or try a different DVD reader to copy the video TS folder.
    If you can’t copy the file in finder it means you can’t access it on the drive. Are you sure it doesn’t have copy protection?
  • Rafael Amador
    March 15, 2012 at 3:23 am
    Forget about HandBrake here. That would convert it to MP4, no good for further processing.
    You need MacTheRipper to get rid of the DVD protection, then MPGStreamclip to convert the MPG_2 to something editable (*b Uncpompressed is the best option).
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    March 15, 2012 at 1:05 pm
    Drag the .VOB files right onto MpegStreamClip, repair time-code breaks, and convert from there.
    Chris Tompkins
    Video Atlanta LLC
  • Sarah Reynolds
    March 15, 2012 at 3:25 pm
    Thanks everyone for the suggestions. I ended up downloading another ripper called WinX. It worked great and gave me an H.264 file that I was able to import into FCP 6 without any issues. I made my edits this morning and it’s all done.
    When I have more time I will definitely look into the timecode break issue.
    Thanks again everyone!!!
  • Rafael Amador
    March 15, 2012 at 3:27 pm
    Yeap. I misunderstood reading that the DVD was protected.
    Drag the VOB files (no copy and paste) to the finder, then import to MPGStreamclip.
    rafael
    Edit: Sorry too late.
