Activity Forums Adobe After Effects Trouble with audio on 6.5 pro
  • Trouble with audio on 6.5 pro
    Posted by Insanedragonz on March 29, 2006 at 5:48 am
    I just recently got my AF 6.5 PRO. However I got a big problem that whenever I import a movie into my timeline I can not hear the audio but can only watch the movie. I tried to mess around with it and found out that I can hear the audio by right click on time line then preview then audio preview (here forward or work area). The problem is I want to watch the video and hear the audio at the same time. Any help would be greatly appreciate 🙁
    Jim Kanter replied 20 years, 5 months ago 2 Members · 3 Replies
  • Jim Kanter
    March 29, 2006 at 9:06 pm
    Make sure the audio switch is turned on in the Time Controls window and do a RAM preview. Be sure to set the audio preview duration to more than the default 8 seconds in the user preferences.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Insanedragonz
    March 30, 2006 at 2:41 am
    Hey I try but didnt work 🙁
    I checked and the audio symbol is on
    I changed Audio preview from 8 to 10
    however when I try to use the RAM PREVIEW, I got an error say that you need 2 or more frames to play back.. 🙁
  • Jim Kanter
    March 31, 2006 at 4:01 am
    Check to make sure that the Work Area is covering the composition.
    Go to the start of the comp and press B, then go to the end and press N.
    Jim Kanter,
