Activity Forums Adobe After Effects Trouble w/ wipe in CS4
  • Trouble w/ wipe in CS4
    Posted by Jeff Davis on June 13, 2010 at 8:40 pm
    I’ve applied a linear wipe to the titles in a movie I’m working on (see attached clip). I’ve precomp’d the titles (animated with the Raining Characters In preset) on a black solid layer, then applied the wipe effect to the comp (you can see the setup in the uploaded screenshot). Everything works fine until the wipe gets to the “s” in “Emery’s” (8:16, 66% indicated completion) at which point it jumps to completion, even though indicated completion at the next frame (8:17) is only 67% completion. How can I fix this? I’m a newb so I assume I’m doing something wrong. Thanks.
    Jeff Davis replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
