Activity Forums Adobe Premiere Pro Trouble Syncing P2 24p footage with 29.97 audio
  • Trouble Syncing P2 24p footage with 29.97 audio
    Posted by Arlo Ihrig on February 19, 2012 at 6:09 am
    Hi All,
    I’m new at syncing footage in PPro (using CS5.5 on Win7), but I’ve studied the manual and watched several videos on the subject but I’m just not getting anywhere.
    Here’s what I’ve got (including just the pertinent details hopefully): Footage shot on a Panasonic HPX-500, 24p, and audio recorded separately using SMPTE 24fps.
    The problem I’m having is that the timecodes seem to be off, but less than a single frame. Therefore if I sync using the timecodes, the audio is just slightly off. If display audio time units, I can sync the clips manually, but its a real pain because I’ve got a completed timeline that I now have sync all the external audio to.
    Has anyone run into this and solved it?
    Thank you very much for your input.
    Arlo
    Jon Frost replied 14 years, 6 months ago 3 Members · 6 Replies
  • Jeff Brown
    February 19, 2012 at 6:43 pm
    Are you sure both frame rates are the same? Because typically, video will actually be 23.98 FPS. If your audio is true 24.00 FPS (which it could be), there’s your problem. I’d fix it by re-timing the audio in Audition or similar app.
    -Jeff
  • Arlo Ihrig
    February 19, 2012 at 7:14 pm
    Hi Jeff,
    Thanks for your reply.
    Here’s the meta data for the video and the audio files. I don’t fully understand the 29.97 pulldown to 24P (though I’ve been watching to videos to try to understand it better), and I’m not sure how this effects the timecode exactly(obviously it does somehow), if the result is that are both supposed to be 24fps in the end.
    Type: P2 Movie
    File Size: 1.5 GB
    Image Size: 1280 x 1080
    Frame Rate: 29.97 (24p)
    Source Audio Format: 48000 Hz – 16 bit – Mono
    Project Audio Format: 48000 Hz – 32 bit floating point – Mono
    Total Duration: 00:01:48:20
    Average Data Rate: 13.7 MB / second
    Pixel Aspect Ratio: 1.5
    Type: Windows WAVE audio file
    File Size: 15.3 MB
    Source Audio Format: 48000 Hz – 24 bit – Mono
    Total Duration: 00:01:51:05328
    Average Data Rate: 140 KB / second
    Sound Dev: 744T S#461007017005
    sSPEED=023.976-ND
    sTAKE=1
    sUBITS=$01151201
    sSWVER=2.67
    sPROJECT=
    sSCENE=15-2
    sFILENAME=15-2T001_2.WAV
    sTAPE=120115
    sTRK2=Track B
    sNOTE=
  • Arlo Ihrig
    February 20, 2012 at 3:27 am
    I have a little bit of an update:
    I figured out a work around based on someone’s suggestion – I found the difference in samples using the audio display, and found that if I sync my clips using timecode, then nudge everything by +2200 samples the audio matches nicely – but I don’t like having to do this.
    This is a real pain in the butt and I’ve now spent my whole weekend trying to get this to work. I’m really hoping Adobe will have some insight into this and either a fix/suggestion or something. Its added a couple steps to my workflow – and I’m just working on the dialog with 4 channels – glad I don’t have more.
  • Jeff Brown
    February 20, 2012 at 4:27 pm
    Is it possible to genlock the video and audio systems? They have to be connected/synchronized somehow, or you will most likely have drift (as you found).
    -Jeff
  • Arlo Ihrig
    February 21, 2012 at 5:33 am
    Well, the footage has already been shot, so I’m trying to do clean-up at this point. It does seem there is a small discrepancy in the length of the external audio, by several samples, maybe 2200/48000ths smaller.
    This is really driving me nuts, but I guess I don’t have anything else but manually adjust them all to be somewhere in the middle to hide the drift. It probably won’t be noticeable to anyone but me.
    But I have to think Adobe would know something about this, and I haven’t heard back from them on this.
  • Jon Frost
    February 25, 2012 at 7:44 am
    Arlo:
    Looks like your clips are really shot in 29.97 not 24p which would be 23.976.
    Your audio was recorded at 23.976.
    Rerecord your audio in Audition at 29.97. Make sure your Sequence Preset is set for 29.97.
    You can use PluralEyes for syncing the audio to video, though you have to futz around with the settings depending on the quality of your camera audio (scratch track only) and your SD744T. I normally use Level Audio, Try Very Hard and Multiprocessing.
    Jon Frost
