Activity Forums Boris FX Particle Illusion Trouble setting background animation images
  • Trouble setting background animation images
    Posted by Leigh Young on June 9, 2009 at 7:36 pm
    I’m having problems setting the background as an animation. When I select background image, I then select 001.png of 65 pngs in the same folder. But when I click open it just reopens the window I was just in to choose an image. I choose 001, 010 or even the last file in the sequence but to no avail. This problem is with pngs and jpegs. Sometimes I can work around it but other times I really do need to see the animation I’m putting the particle with. Restarting the program doesn’t help.
    Alan Lorence replied 17 years, 2 months ago 2 Members · 1 Reply
  • Alan Lorence
    June 9, 2009 at 11:57 pm
    Don’t use only numbers in the filenames. If you use “image001.png”, “image002.png”, etc. it will work fine.
    Or even “a001.png”, “a002.png”, etc. It just needs something before the numbers.
    Alan.
    http://www.wondertouch.com
