Activity Forums Adobe After Effects Expressions Trouble scripting Injecting expression on “Rotate”
  • Trouble scripting Injecting expression on “Rotate”
    Posted by Raphael Luz on September 2, 2022 at 9:25 pm
    Hello friends,
    i’m trying to simply my workflow…so i tried to create a script to inject a expression on Rotation property of selected layers (not just only one)
    Unfortunately i’m very bad at this, and i frequently get lost in expressions reference guides 🤣
    Can please some good soul help me?
    The best i could do:
    (function () {
    if(app.project.activeItem == null || !(app.project.activeItem instanceof CompItem)) {
    alert(“please select a valid item”);
    return false;
    var myComposition = app.project.activeItem;
    var myLayer = myComposition.layer[0];
    myLayer.property(“ADBE Transform Group”).property(“ADBE Rotate”).expression = ‘value – parent.transform.rotation’;
    My plan is to use this script at KBar
    Thanks in advance
    Raphael Luz replied 4 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 3, 2022 at 12:32 am
    Like this, I think:
    (function () {
    alert("please select a valid item");
    return false;
    var myLayers = myComposition.selectedLayers;
    for (var i = 0; i < myLayers.length; i++){
    myLayers[i].property("ADBE Transform Group").property("ADBE Rotate Z").expression = 'value - parent.transform.rotation';
  • Raphael Luz
    September 5, 2022 at 3:14 pm
    Amazing! Worked fine…thank you very much!
    Expression legend 🤩
