Activity Forums Adobe Premiere Pro Trouble saving to a striped volume…
  • Trouble saving to a striped volume…
    Posted by Alex Udell on March 10, 2006 at 2:11 pm
    Hi Guys…
    With a Matrox Axio Configuration:
    1) Promise Controller card
    2) Internal SATA RAID
    3) Per Martox config: 64k cluster format of drives
    4) Premiere Pro 1.5.1 with Axio 1.5 drivers
    Experiencing the following:
    1) Can’t save a Photoshop file directly to the Striped set
    2) Can’t save a Encore Project directly top the striped set
    in both cases, Application reports that the disk is full.
    3) Files can be saved to C: and copied to the striped set manually
    Both Premiere and Audio save fine and Premeiere captures to the media volume with no problems.
    4) Can’t defrag Striped volume using Windows Defrag or the full version of Disk Keeper
    I suspect the 64Kb clustering to be the root of the issue….but just wanted to bounce these symptoms off everyone…
    Anyone else seen this?
    Thanks….
    Alex
    Alex Udell replied 20 years, 5 months ago 4 Members · 9 Replies
  • 9 Replies
  • Eric Jurgenson
    March 10, 2006 at 2:32 pm
    Yes, I see it. I have an Axio with an external SATA RAID (U320 SCSI interface). I think you’re on to something.
  • Alex Udell
    March 10, 2006 at 3:02 pm
    Hi E,
    What’s your controller card and gerenal config?
    Thanks…
    Alex
  • Steve Spaw
    March 10, 2006 at 4:25 pm
    I have seen this many times before with Adobe apps.
    Is your Striped set in the 2 TB range or larger?
    If the answer is yes then you will have to partition the drives into 1.5 TB or smaller to write to them from some Adobe apps.
    Photoshop 7 would not write to anything over 1TB
    I wish that they would fix these issues.
    Good Luck,
    Steve
  • Alex Udell
    March 10, 2006 at 5:05 pm
    Steve….
    very interesting….
    I’ll check it out…
    thx…
    Alex
  • Eric Jurgenson
    March 10, 2006 at 5:19 pm
    That would explain it. I have a 4.5 TB array. Partition Magic time.
  • Alex Udell
    March 10, 2006 at 8:26 pm
    Is this still true as of PS CS2?
    my client is using PS 7
    Alex
  • Peter Corbett
    March 11, 2006 at 7:09 am
    I’m running a 1.5 Terabyte array and can save all types of Adobe files with a a LSI 320-2E PCIe Megaraid at x8.
    Peter Corbett
    Powerhouse Productions
    Australia
    http://www.php.com.au
  • Steve Spaw
    March 11, 2006 at 1:18 pm
    Yes Peter, 1.5 TB should be fine for all of the new apps. The next hurdle comes at 4 TB, I have not had the ability to test this configuration.
    Anyone out there with new Adobe Collection and over 4TB of storage?
    Let us know.
    Steve
  • Alex Udell
    March 11, 2006 at 2:34 pm
    Well…
    Encore is giving fits at 1.2 TB.
    (at least the one with the previous video collection)
