Activity Forums Avid Media Composer Trouble Relinking Resolve-Transcoded Media in Avid – Any Ideas?
  • Trouble Relinking Resolve-Transcoded Media in Avid – Any Ideas?
    Posted by Nacho Santana on April 30, 2025 at 11:35 am
    Hey all,
    I’m running into a weird relinking issue in Avid and I’d love to hear if anyone’s seen this before.
    I have a clip (P0001420) that I transcoded in both DaVinci Resolve and Avid (same clip, just two workflows). In theory, I should be able to relink either one, right? Especially since they’re both DNxHD LB 1080p, same TC, same duration, same everything.
    But Avid refuses to relink to the Resolve version.
    Here’s the setup:
    • Avid-transcoded clip shows up fine.
    • Resolve-transcoded clip shows “Created by Resolve” in Avid.
    • Both clips are exactly the same length (3:21), same name, same audio config, etc.
    Here’s a side-by-side comparison of how they appear in Avid:
    – [https://imgur.com/a/Svr4JYE]
    And here are my Conform Options in Resolve when I export the AAF and transcode to MXF OP-Atom:
    – [https://imgur.com/FLieVh7]
    I used:
    • “Assist using reel names from: Source clip filename
    • Timecode from source
    • DNxHD LB (1080p)
    I rarely mix transcodes like this, but in theory, Avid should be able to relink either version of the media to the same sequence, no? I’m guessing the issue might be coming from metadata differences — maybe reel name or the way Avid handles “tape name” on import?
    Has anyone successfully relinked Resolve-transcoded MXFs to Avid media or sequences that were originally built using native Avid transcodes?
    Would love any insight — cheers in advance!
    Glenn Sakatch replied 1 year, 3 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    June 7, 2025 at 3:28 pm
    I do transcodes out of Resolve all the time. I don’t usually transcode out of Avid, but I have. But no, i have never tried to transcode the same file at the same resolution out of both programs , and then switch back and forth.
    Honestly, my first question is “why?” It sounds like you are trying to see how far you can go before you confuse the program.
    Are you rebuilding the media database each time you try to do this? Are you removing one file and replacing it with the other. A bit more on your steps might help, as well, if you could post the files, i can take a look on my end.
