Activity › Forums › Apple Final Cut Pro Legacy › Trouble reconnecting media after changing hard-drives
  • Trouble reconnecting media after changing hard-drives
    Posted by Neil Orman on June 23, 2013 at 3:27 pm
    I was having trouble with my FCP7 crashing while using one hard-drive, so I transferred the media to a different hard-drive. Now I’m having trouble reconnecting the media, so I can’t view or edit my sequence. My video was all shot with a tapeless Panasonic AG-HPX170 camcorder with P2 cards, and I originally used ‘log and transfer.’ What I’ve tried is selecting individual clips and choosing ‘reconnect media.’ But when I do that and try to select the entire folder, because individual clips are separated into all these component parts with this camera, I can’t select the entire folder because it won’t let me, nor can I find the individual clip. If anyone can advise me how to reconnect this media I would certainly appreciate it!
    Thanks a lot,
    Neil
    Nick Meyers replied 13 years, 3 months ago 3 Members · 3 Replies
  • Steve Eisen
    June 23, 2013 at 4:07 pm
    It would seem obvious to use log and transfer. You need to use batch capture to re-ingest the media.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Neil Orman
    June 23, 2013 at 5:12 pm
    That is a big help, thank you Steve.
  • Nick Meyers
    June 24, 2013 at 12:54 am
    what format did you transcode to with Log & transfer?
    it seems as if you might have the original card media on the same drive as your transcodes,
    and Reconnect is finding that.
    maybe you need to use “Locate” and direct FCP to the transcodes
    OR
    make sure the new file path is identical to the old one,
    same folder structure
    AND that includes naming the drive exactly the same.
    then there should be no problem at all.
    nick
