Activity Forums Apple Final Cut Pro Legacy trouble printing to tape
  • trouble printing to tape
    Posted by Ryan Cornish on May 16, 2005 at 5:26 pm
    When I export to tape I am getting pixilized video and no audio back to the tape. I am running FinalCut Pro HD 4.5. I have tried to nest the clips and mixdown the audio with no success. I have a project that will dump to tape and have checked all of the settings to make sure they were the same and have had no luck. I have also put filters on all of my audio clips to make it write new files and still no success…..please help!
    Shane Ross replied 21 years, 3 months ago 5 Members · 6 Replies
  • Jason Mccaffrey
    May 16, 2005 at 5:57 pm
    Do a search for “master to tape”, “print to video”, and “dropped frames” and you will retrieve a ton of steps for trying to solve this problem.
    Here are a few quick suggestions:
  • Don Greening
    May 16, 2005 at 6:03 pm
    Ryan,
    I also responded again to your post from yesterday, but Jason’s suggestion about exporting the QT self contained .mov and then importing into a new timline is an exellent one. I should have thought of that one as well.
    – Don
  • Ryan Cornish
    May 16, 2005 at 6:14 pm
    Thanks a ton Guys. I will give it a try.
  • Kevin Monahan
    May 16, 2005 at 6:31 pm
    How does it look on the video monitor? Do you still see the dropouts?
    No Audio? Make sure the speakers are connected to the deck/camcorder.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Ryan Cornish
    May 16, 2005 at 6:41 pm
    It looks fine on the monitor. No drop out and all audio sounds fine. I’m using firewire to put back to tape. I know it’s not working when I dump back when the audio meters just don’t move during print to tape.
  • Shane Ross
    May 16, 2005 at 7:17 pm
    ” I know it’s not working when I dump back when the audio meters just don’t move during print to tape.”
    Don’t judge it by this. ONLY judge it by the image and audio you are getting from a TV or NTSC monitor you have connected to your camera/deck. Depending on the speed of your system, the meters might not refresh often (visually) and look like they are not moving.
