Activity Forums Adobe Premiere Pro Trouble Opening Premiere Pro 2.0 projects in CS3
  • Trouble Opening Premiere Pro 2.0 projects in CS3
    Posted by Michael Panfeld on April 14, 2008 at 6:20 am
    Hi: I am having trouble opening a PP CS2 project in CS3. All of the files are in the project folder, but the timeline is completely blank. In fact, there isn’t even a place to drop down audio or video clips in the timeline. I am on a PC, using Windows XP Pro. Help!
    Michael Panfeld replied 18 years, 4 months ago 3 Members · 4 Replies
  • Jon Barrie
    April 14, 2008 at 8:22 am
    u need to find the seq timeline in the project tab. open that, you’ll b fine. this empty timeline is a bug in cs3. not problem just annoying.
    – jon 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Larry Schutte
    May 21, 2008 at 1:56 am
    I’m having the same trouble but can’t find the sequence to timeline command in the project tab. Help! Larry
  • Larry Schutte
    May 21, 2008 at 1:58 am
    Mike- Did you find an answer? I’m having the same trouble. Larry
  • Michael Panfeld
    May 21, 2008 at 7:12 am
    John was right. its there, you just have to open it up and populate the timeline. It doesn’t do it automatically. Its like its “collapsed” so you can’t see anything.
    Once you put it in the timeline, its all there. cheers
