Trouble moving an image around in FCP
Hi. I’ve got a big image of a chart in my final cut pro project.
https://artornothing.com/duffy/blog/chart1.jpg
I want to camera to pan around all over the chart, so I set a bunch of motion keyframes for it, but when it moves from keyframe to keyframe, it does this:
https://artornothing.com/duffy/blog/chart2.jpg
It’s like it’s splitting the frame in two. This happens for fast moves and slow moves. I tried turning off frame blending but I guess that’s not what it is because it didn’t change anything.
How can I get it so it just fills in the frames while keeping the image stable? I had this same problem with a much shorter, simpler clip of moving a camera across a photo. My solution was to re-do the keyframing in flash, and flash had nice smooth motion without this splitting effect. This new one has way more keyframes, and I’m wondering if there’s a setting or filter that I need to get smooth motion from a still image?
