Activity Forums Adobe Encore DVD Trouble making BluRay with Adobe Encore
  • Trouble making BluRay with Adobe Encore
    Posted by Anthony Botta on August 6, 2016 at 6:46 pm
    I have Adobe Production Premium CS5. Yes I know it is old but it serves my purpose and I have no desire to update.
    So far I have always made either mp4 files or burned standard DVD’s. I am finally trying to do a BluRay and have had no luck.
    I record with a Sony EX1r Camera at 1080P 30FPS in the Sony XDCAM EX format.
    I have my premiere project done for a video just under 2 hours. Normally I would export (downgrading the high def) to mpeg2 DVD when I want to burn a DVD project.
    This time I have tried a few combinations for making a bluray. Everything is set in encore and the preview is fine. But when I try to build to a Bluray Image, it fails saying not enough free storage, code 25. I made sure when encoding the video that it was less than 25 GB (I used a bitrate calculator as I always do). I read that bluray does not support 30P, only 60i, so maybe that is the problem? But I don’t see how to fix this. I also tried burning to a bluray folder which is successful. Then I tried converting that to a bluray image using Nero, but the bluray image will not play.
    I tried both mp4 and mpeg 2 bluray options in premiere. I don’t see any options for 60i.
    All I see for mpeg2 bluray is:
    – Match Source Attributes (High Quality)
    – Match Source Attributes (Medium Quality)
    – 1440 x 1080i 25 High Quality
    – 1440 x 1080i 29.97 High Quality
    – 1440 x 1080p 24 High Quality
    – HDTV 1080i 25 High Quality
    – HDTV 1080i 29.97 High Quality
    – HDTV 1080p 24 High Quality
    – HDTV 720p 24 High Quality
    I tried 1080i 29.97 but that also didn’t work.
    Can someone help me on what I should render my premiere pro video out to in order to be able to burn a bluray?
    Thank you.
    System specs (no overclocking):
    –OS: – Microsoft Windows 7 Ultimate (64 bit) SP1 with latest updates.
    –Monitor: – Dell UltraSharp U3011 30-inch Widescreen
    –Case: – COOLER MASTER HAF X RC-942-KKN1 ATX Full Tower
    –Motherboard: MSI Big Bang-XPower LGA 1366 Intel X58 wit latest BIOS (v1.7)
    –CPU: – Intel Core i7-980X Extreme Edition Gulftown 3.33GHz
    –CPU Cooler: – CoolIT Systems VAN-R120 Vantage A.L.C. Liquid Coole
    –Power Supply: – CORSAIR Professional Series AX1200 1200W
    –Sound Card: – Creative Sound Blaster X-Fi Titanium Fatal1ty
    –Video Card: – EVGA GeForce GTX 980ti SC+
    –Memory: – G.SKILL Ripjaws Series 24GB (6 x 4GB) 240-Pin DDR3 SDRAM
    –Memory Cooler: – G.SKILL FTB-3500C5-D Fans
    –1st Hard Drive: – SAMSUNG 850 PRO 256GB SSD
    –2nd Hard Drive – SAMSUNG 850 PRO 256GB SSD
    –3rd Hard Drive: – Western Digital VelociRaptor WD1000DHTZ
    –4th Hard Drive: -Seagate Barracuda XT 2TB 7200 RPM 64MB Cache
    –1st Optical Drive: – LG WH10LS30K 10X Blu-ray Burner
    –2nd Optical Drive: – LG WH10LS30K 10X Blu-ray Burner
    –Keyboard/Mouse: – Logitech MX 5500 Revolution Bluetooth Cordless Desktop
    –Card Reader: Nippon Labs Delux 3.5″ Internal Card Reader/Writer
    –Speakers: – Altec Lansing ADA995 5.1 surround speakers
    Anthony Botta replied 10 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
