Activity Forums Adobe After Effects Trouble keying around hair
  • Trouble keying around hair
    Posted by Michael Rose on October 13, 2016 at 5:23 pm
    I’ve had no luck getting a good key around a subject with stringy hair. Admittedly, our lighting and setup wasn’t as good as it could have been, but I’m wondering if anyone has any tips? I’ve tried different keying approaches in Final Cut and AE with no luck. I’m not particularly experienced with either program, so I very well could be missing some tactics.
    I’ve uploaded a portion of the original video file for review.
    Karl Ricker replied 9 years, 11 months ago 4 Members · 5 Replies
  • Bruce Gaber
    October 13, 2016 at 5:59 pm
    I’m just getting up to speed on keying myself, but I can offer a couple of very basic suggestions. Within AE are you using the KeyLight effect? It is considered by many to be one of the very best and most versatile keyers. That being said, it is a tool with something of a learning curve. There are a number of good tutorial out there. I’m working thru the one on Lynda.com at the moment. If you go to https://www.thefoundry.co.uk/support/user-guides/ you’ll find a user guide to KeyLight for AE. They also have links to tutorials.
    Good luck!
    Bruce
    Photographer / Motion Graphics Artist
    Vision Rising
    vimeo.com/BodhiBruce
    visionrising.com
    Dance Without Reason
  • Michael Rose
    October 13, 2016 at 6:01 pm
    Hi Bruce. Yes, I’ve tried using Keylight, and it is a very good tool. However, I just can’t seem to get the key right around her hair. If you notice in the video I shared, there are some frizzy strands that are causing the trouble. We should have been more cognizant of that (and the lighting) up front, but unfortunately, we didn’t pay it enough attention.
  • Roei Tzoref
    October 13, 2016 at 6:39 pm
    I’m on my iphone so can’t watch the video but this sounds like you need to combine keyed mattes to get optimal results with edge detail. There are several ways to do it and I would recommend learning the workflow here: https://www.lynda.com/After-Effects-tutorials/After-Effects-Compositing-04-Color-Keying/114914-2.html you can get 7 days for free pn Lynda, I subscribed years ago.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Roei Tzoref
    October 14, 2016 at 12:23 am
    I had some time to test your footage. if this is the quality of your footage (4:2:0 is bad for keying unless shot in optimal circumstances ) and you can’t get any better (at least 4:2:2 or maybe less compressed if you compressed it further prior to uploading it), my suggestion would be to use rotobrush + refine edge tool for the hair/head, and keylight for the rest. the compression is too harsh it just eats up the fine hair detail.
    with rotobrush and refine edge tool you can get good edges. it will require patience and perseverance in a proper rotobrush workflow but this is how I would do it unless you can compromise the hair with some softness or feather.
    Roei Tzoref
  • Karl Ricker
    October 14, 2016 at 1:16 pm
    You could also use the footage as a luma matte for itself. Place it on a layer above itself. Set the layer below it to use it as a luma matte. Then use effects to make the top layer black and white, invert it and then use level controls to adjust it as needed.
    -Karl Ricker
