Activity Forums Adobe Audition Trouble installing a plugin
  • Trouble installing a plugin
    Posted by Richard Jay on November 8, 2007 at 6:00 pm
    Hi
    Hope somebody can throw some light on a problem i’m having!!
    I’m trying to install Antares AutoTuneDX. I have been given a copy of version 4 which is no longer being used.
    I ran it’s self install file and it asked me if I wanted to register which I did – all fine.
    Appears as a plugin in Cubase but is nowhere to be seen in Audition. I have never used plugins before, am I doing something wrong? It says in the txt files it’s compatible with Audition.
    Cheers for any help
    Regards
    Richard
    Peter Benedickter replied 18 years, 9 months ago 3 Members · 2 Replies
  • Blast1
    November 9, 2007 at 7:57 pm
    Autotune 4 shows up as a directx plug-in.
    Here is a fix thats floating around, this needs you to edit the registry, don’t if you aren’t sure what you are doing(you are on your own)
    1) Close Adobe Audition
    2) Open the registry by going to the Start menu, selecting Run, then typing regedit and clicking OK
    3) Under HKEY_LOCAL_MACHINE,
    go to the key \SOFTWARE\Adobe\Audition\PlugIn\DirectX
    4) Locate the data item whose Name is {02A06B08-744E-40E3-8B78-E45D71750DC8}
    5) Delete that item
    6) Close the registry
    7) Run Adobe Audition
    8) In the Edit view, select the menu item Effects -> Refresh Effects List
    Auto-Tune 4 should now appear under the DirectX tree in the Effects list
  • Peter Benedickter
    November 24, 2007 at 12:53 am
    hi i am unfamiliar with mac os x which i am currently controlling my cubase from so i need some help. How do you install plugins into cubase??? as i have a CD loaded with plugins which im dying to get going.
    please give me feedback
    thanks for any help
    regards
    peter b
