Activity Forums Apple Final Cut Pro Legacy trouble importing jpegs
  • trouble importing jpegs
    Posted by Chris Monette on May 30, 2005 at 3:04 pm
    I’m working in a DV NTSC sequence and I’m having trouble playing jpegs. I can put them in the timeline, but evertime I do I get a message that says: Codec not found. Display is unavailable. Select a different codec using sequence settings.
    I’ve never had this problem with jpegs before. I converted them to RGB, so I know it is not a colour issue. I’ve even tried to convert them to TGAs and TIFFs and I get the same result every time. Is there anything else I need to do to the images to make them work?
    Chris
    FCP 4.5
    G4 Powerbook/G5 Mac
    lots of RAM
    lots of Drive space
    Bjørn Holmgren replied 21 years, 3 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    May 30, 2005 at 3:24 pm
    Trash or put your preference file for FCP aside, create a new project file and sequence and see if this doesn’t clear things up.
    Jerry
  • Chris Monette
    May 30, 2005 at 3:36 pm
    Thanks Jerry. This didn’t work though. Changing the files to 16 bit TIFFs seems to work though. Problem is, I have 820 pictures to go through and using automate batch in Photoshop requires me to save them 1 at a time.
  • Bjørn Holmgren
    May 30, 2005 at 9:13 pm
    Strange – I have only seen this with CMYK images. Why doesn’t batch conversion in PS work for you?
    Regards,
    Bj
