Activity Forums Adobe Premiere Pro Trouble importing in Premier pro 7
  • Trouble importing in Premier pro 7
    Posted by Nate Ward on April 4, 2005 at 10:25 am
    I have several large DV avi files (10+ gigs) which I captured using a third-party program, and I am trying to import them into Premier, but Premier only seems to import the first 5 minutes correctly. After that, it will only display the frame at the 5 minute mark.
    I tried setting an in and out for the import, but same problem. If the i/o points were after 5 minutes into the clip, only a single frame lasting whatever duration was imported.
    This is not just a lag or something, I tried exporting from premier and it was the same.
    Any ideas? Any help is greatly appreciated.
    Nate Ward replied 21 years, 5 months ago 2 Members · 2 Replies
  • Mike Velte
    April 4, 2005 at 12:32 pm
    What 3rd party capture app?
    There are many DV codecs, some support files only up to 2 GB.
    There 2 Microsoft DirectShow DV codecs, Premiere only works with type 2. (
  • Nate Ward
    April 4, 2005 at 3:48 pm
    I used iuVCR to capture. I tried importing the video on a computer with Premier Pro 1.5 (instead of 7), and it seemed to work fine. Strange…
