Activity › Forums › Adobe After Effects › Trouble importing Illustrator layers to AE
Posted by Clarke Flippo on August 28, 2014 at 9:03 pmI have an Illustator file with multiple layers that I need to import into AE. I’ve released all layers to sequence inside Illustrator and I’ve been importing into AE as Composition – retain layer sizes. All AE does is bring in the ai file and no layers. From what I know, these are the correct steps. I even made sure my ai file was RGB. Please help. Thanks.
Jacqueline Greff replied 10 years, 11 months ago 5 Members · 7 Replies -
Todd Kopriva
August 29, 2014 at 12:26 amAre you sure that you have multiple layers in Illustrator? Some folks get confused between objects and layers in Illustrator and have multiple objects on a single layer, rather than having multiple layers. The Release To Layers command is useful for preparing Illustrator files for After Effects:
https://helpx.adobe.com/illustrator/using/layers.html#release_items_to_separate_layers———————————————————————————————————
After Effects team blog
Cassius Marques
August 29, 2014 at 5:41 pmWhile saving, make sure “Create compatible pdf file” is checked (something like that since mine is in another language).
Clarke Flippo
August 29, 2014 at 7:22 pmProblem solved! I was unaware that when you release layers to sequence a top level layer is still present, which you must delete for AE to read the other layers. Thanks guys!
Joanne Lediger
August 6, 2015 at 3:02 pmWhere do you delete this top level layer? I release to layers and everything is separated, bu I bring it into AE as a comp (retain layers sizes) but all I see is the one object inlayered…
Clarke Flippo
August 6, 2015 at 4:15 pmIn the Layer panel in Illustrator there is a layer at the very top of all your layers which groups them all together. Highlight all layers below this one and move them out of the group. Then delete the group layer. This will allow AE to read your illustrator layers.
Jacqueline Greff
September 5, 2015 at 1:34 amI had an Illustrator file I was trying to import into After Effects and it wasn’t working. I had unchecked “Create compatible pdf file” not realizing how important it was. Works perfectly again. Thanks!
