Activity › Forums › Adobe Premiere Pro › Trouble importing FCP captured quicktime files to premiere CS4
  • Trouble importing FCP captured quicktime files to premiere CS4
    Posted by Stephen Webster on October 2, 2009 at 5:21 pm
    Im having trouble importing FCP captured HDV footage into premiere CS4, in this project i am using P2 footage and soon to be red also. However when trying to play the HDV footage it keeps saying i do not have the supported codec. the same goes for when i try to open the file in the desktop, it simply sends me to apples codec website and as such i am unsure as to which codec i require as i have never encountered this problem before. On the opened Quicktime file the audio plays but no video (either that or the lens cap never came off!) I have the latest version of quicktime installed and am a little bit stumped at this problem. I am running on Vista home premium (please dont be a vista problem… not another one!!!)
    If anyone knows what the issue is and can help you would be a life saver to me
    Stephen Webster replied 16 years, 11 months ago 3 Members · 5 Replies
  • Jeff Brown
    October 2, 2009 at 7:42 pm
    My guess would be it’s using the Apple ProRes codec. Now available for windows:
    Apple ProRes.
    In QTime Player, the “Info” window will sometimes tell you what codec was used for the video stream.
    -Jeff
  • Stephen Webster
    October 2, 2009 at 8:39 pm
    Hi Jeff,
    Thanks for helping but no luck i’m afraid. because i’ve got the latest version of quick time (not Pro) pro res should already be installed as it keeps telling me when i try to install it. as for the ‘info’ bar it doesnt give me any relevant data. oddly enough the files play in VL media player and in total video converter but when i try to export them in it i either get a watermark or the image looks like its been through a mincer. is there any chance i might need a HDcam codec for windows or something similar, either that or is it apples way of making you upgrade to quicktime pro?
    thanks for your help and your time though
    -Ste
  • Jon Barrie
    October 3, 2009 at 8:51 am
    You are dealing with an Apple intermediate codec, so on Windows you are pretty much stuck. Someone around was saying they used I think Raylight to get FCP converted P2 footage to work on a Windows system.
    If you have the original CONTENTS folder and all the originally recording folder/file structure you can edit with that in CS4.
    Try looking around. this is not a new problem. Thanks to Apple.
    You’ll find you either need a mac, buy raylight, or get someone with a FCP system to completely convert all the footage to something that is cross platform, like ProRes or Uncompressed.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Stephen Webster
    October 3, 2009 at 3:21 pm
    Hi John,
    Thanks for your help but after all night downloading video converters and reading forums i think i’ve found a solution. The problem itself it turned out was that FCP encodes the files as a HDV 3 codec wich essentially ties it to Mac’s only. it would of made sense for me to go find a mac and rexport the footage or the timeline as an xml file so i could bring it into premiere but as that isnt an option i’ve had to work around it (much to my ‘delight’) As it seems a program called ‘Any video converter’ seems to do exactly what it says on the tin albeit a bit slowly but its just what im going to have use for now. Thanks for your time though
    Ste Webster
    you can download the converter from here
    https://download.cnet.com/Any-Video-Converter/3000-2194_4-10661456.html?tag=mncol
    Hope this helps anyone else in the same situation as myself
  • Stephen Webster
    October 13, 2009 at 6:44 pm
    Actually just found a much better and more useful bit of conversion software ‘Wondershare video converter platinum’ This software is perfect for working round and re-converting your HDV3 codec files. you can also open up multiple instances of the program too so you can render multiple files at once. This has saved me a lot of time and a few tears i can say.
    Just thought i’d pass on the info for when the same problem happens to someone else
    I feel a little happy for beating apple there 😉
    Thanks everyone for your help
