Activity › Forums › Apple Final Cut Pro Legacy › Trouble importing Canon c300 footage with Log and Transfer
  • Trouble importing Canon c300 footage with Log and Transfer
    Posted by Ivan Kuzmin on January 6, 2014 at 12:58 pm
    Hi all!
    I’m having trouble importing Canon c300 footage with Log and Transfer in FCP 7.0.3. The media is added to the list, but the thumbnails and the canvas are black. There’s audio when I try to play it, but no video and when I try importing, it fails. Used to work perfectly just a few days ago. I have the latest XF Plugin installed. What am I doing wrong?
    Mika Hudyma replied 12 years, 8 months ago 3 Members · 3 Replies
  • Shane Ross
    January 6, 2014 at 5:27 pm
    Did you install anything new from the time it worked to the time it didn’t? Do you know what frame rate was shot?
    have you tried trashing your FCP preferences?
    Shane
    Little Frog Post
  • Ivan Kuzmin
    January 6, 2014 at 5:45 pm
    Well, the station is used by many people but they all claim they haven’t changed anything.
    It was shot at 25fps, at least has to be.
    I tried trashing, yes. Didn’t help 🙁
  • Mika Hudyma
    January 18, 2014 at 9:39 pm
    I just encountered exactly the same problem on 2010 Mac Pro running 7.0.3. Have trashed prefs, reinstalled three different versions of plugin and while log and transfer loads the volumes, when a clip is selected audio only plays for 1-2 seconds and then nothing.
    Same set-up works fine on Macbook Air. No recent installs on Mac Pro. The Canon utility works fine as do other codecs in log and transfer.
    Any thoughts are appreciated. I see a few other posts here about same problem: all after the first of the year.
    Mika
