Activity Forums Apple Final Cut Pro Legacy Trouble getting text to move across screen smoothly
  • Trouble getting text to move across screen smoothly
    Posted by Lee Burrows on September 24, 2012 at 9:51 pm
    Hey everyone! Is there a way to get text to smoothly scroll across the screen(left-right;right-left)? The text artifacts in Final Cut whether I go across or up/down and it is annoying. It even artifacts on my computer so it is not interlacing. I have tried exporting motion quicktime movie files to see if that works with no luck. Any suggestions? Is there a filter or a way in After Effects to smooth out a scroll?
    Mac OS X (10.4.10)
    1.5 GB DDR SDRAM
    Dual 2 GHz Processor
    Power PC G5
    FCP 5.1.4
    Black Magic Decklink Extreme
    Sony UVW 1800
    Motion 3
    Mac OS X (10.5.6)
    16 GB 667 MHz DDR2 FB-DIMM
    Dual 2X3 GHz Dual Core intel Xeon
    FCP 6
    AJA Kona LHe
    Lee Burrows replied 13 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Gissing
    September 24, 2012 at 10:55 pm
    Try Boris crawl set to horizontal movement. FCP moving text gens are awful.
  • Joseph Owens
    September 25, 2012 at 4:15 pm
    [Michael Gissing] “FCP moving text gens are awful.”
    Pretty much. Some people are fans of the graphic treatments available in Motion. LiveType was pretty good, but Apple didn’t like it. CHV offered some plugins for scrolls that allowed for some pretty cool formatting, but a little bit flaky — half-lines of text turning on and off at the top and bottom of screen when leading or following a graphic, for example.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Bret Williams
    September 25, 2012 at 7:18 pm
    [Joseph Owens] “LiveType was pretty good, but Apple didn’t like it”
    It always seemed to me that LiveType was in some small way the basis of the way Motion worked. And later the basis for how some of iMovie and X worked. Just little bits, but then, LiveType itself was just a little bit.
  • Lee Burrows
    September 25, 2012 at 8:50 pm
    Thanks. I appreciate the suggestions.
    Is there one simple way to move text left-right or right-left? Nothing is working for me so far 🙁
    Mac OS X (10.4.10)
    1.5 GB DDR SDRAM
    Power PC G5
    FCP 5.1.4
    Sony UVW 1800
    Motion 3
    Mac OS X (10.5.6)
    FCP 6
    AJA Kona LHe
  • Bret Williams
    September 25, 2012 at 11:46 pm
    A crawl or just a few words. I would just keyframe a few words in the motion tab.
  • Lee Burrows
    September 27, 2012 at 11:11 pm
    Thank you to everyone for responding with all these great suggestions. I’ve tried a few other things without success so I figured I let everyone know my timeline specs. Dave LaRonde may be the closest to the problem imo but I am still having it unfortunately.
    Codec:DVCPRO HD 720p60
    960X720
    Frame Rate is 29.97
    I am currently just using Text in FCP and created an A to B move in the controls of text. Maybe I need to try to move the whole frame?
    The clip is on you tube and can be viewed with the link below. The text is at :29 and 1:29 into the video. The clip on you tube is H264 but the problem exists in original file in FCP. It is less pronounced since it is uncompressed in FCP.
    https://www.youtube.com/watch?v=ZPCvn0vSChc
    Thanks again for any input and all your help!
    Lee
    Mac OS X (10.4.10)
    1.5 GB DDR SDRAM
    Power PC G5
    FCP 5.1.4
    Sony UVW 1800
    Motion 3
    Mac OS X (10.5.6)
    FCP 6
    AJA Kona LHe
  • Lee Burrows
    October 1, 2012 at 9:55 pm
    Thanks Dave. I’ll try bringing down the saturation a little and see if that helps.
    Mac OS X (10.4.10)
    1.5 GB DDR SDRAM
    Power PC G5
    FCP 5.1.4
    Sony UVW 1800
    Motion 3
    Mac OS X (10.5.6)
    FCP 6
    AJA Kona LHe
